volpone
Feb 21, 2012Aspirant
Mixing brand model and size to upgrade storage space?
Hello all, I need to upgrade my X86 ReadyNas Pro Pioneer (4.2.19) X-RAID2 4 drives setup to 6 drives setup to get more storage space. The four installed drive models WD 1TB Green WD10EADS-00L5B1 (...
Feb 21, 2012Guru - Experienced User
If your system has XRAID-2, then you shouldn't need to worry about 4K alignment - you should already have it.
volpone wrote:
PapaBear wrote: Sorry, I misread it. I was thinking of the HDS5C3020ALA632 which is the 2TB version of the 3TB drive green drive that is on the list. Mea Culpa.
PapaBear,
However i'm still interested in 2TB Green SPINPOINT F4 HD204UI (on HCL) or 2TB DESKSTAR 5K3000 (amazingly not in HCL for the moment). Do you know if backup and factory reset is needed (4K alignment) using these 2x2TB disks to expand my X-Raid2 setup ?
Thank you.
Volpone
