volpone
Feb 21, 2012Aspirant
Mixing brand model and size to upgrade storage space?
Hello all, I need to upgrade my X86 ReadyNas Pro Pioneer (4.2.19) X-RAID2 4 drives setup to 6 drives setup to get more storage space. The four installed drive models WD 1TB Green WD10EADS-00L5B1 (...
volpone
Feb 22, 2012Aspirant
mdgm wrote: That's not the only option. Take a look at http://www.readynas.com/RAIDiator_x86_4_2_12_Notes
Check your partition.log. If you have the time or if most of your disks are not 4k sector aligned then it would be best to backup and do a factory reset but that is not the only option.
mdgm,
I've checked partition log. Seems all 4 disks are 512 sector.
So i'm afraid i will need to full backup and factory reset my NAS prior to expand my array.
I have an other "small" NAS and several external USB HDD, but i miss a single backup volume with sufficent space (2TB) .
Any pointer to a full data backup procedure (near 2TB needed) on several devices ?
Thank you
partition.log extract
***** partition output for sdd *****
Disk /dev/sdd: 1953525168 sectors, 931.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 9BF39102-7D95-4343-ABFF-489B348716D5
Partition table holds up to 8 entries
First usable sector is 4, last usable sector is 1953525164
Partitions will be aligned on 8-sector boundaries
Total free space is 5101 sectors (2.5 MiB)
Number Start (sector) End (sector) Size Code Name
1 4 8388611 4.0 GiB FD00 Linux RAID
2 8388612 9437187 512.0 MiB FD00 Linux RAID
5 9437189 1953520064 927.0 GiB FD00 Linux RAID
Disk /dev/sdd: 121601 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sdd1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sdd2 0 - 0 0 0 Empty
/dev/sdd3 0 - 0 0 0 Empty
/dev/sdd4 0 - 0 0 0 Empty
