volpone
Feb 21, 2012Aspirant
Mixing brand model and size to upgrade storage space?
Hello all, I need to upgrade my X86 ReadyNas Pro Pioneer (4.2.19) X-RAID2 4 drives setup to 6 drives setup to get more storage space. The four installed drive models WD 1TB Green WD10EADS-00L5B1 (...
mdgm-ntgr
Feb 22, 2012NETGEAR Employee Retired
volpone wrote:
I've checked partition log. Seems all 4 disks are 512 sector.
So i'm afraid i will need to full backup and factory reset my NAS prior to expand my array.
Well you could replace two disks one at a time, hot-remove disk, wait say half a minute then hot-add again, disk will be wiped, then you need to wait for resync to complete then repeat for second disk. Then replace the other two disks one at a time with the higher capacity disks. If you go down this route I'd recommend running the "Test Disks" boot option. It is a good idea to check if a disk is failing. The hot-swap route is an option though I'd prefer the backup and factory default route.
volpone wrote:
I have an other "small" NAS and several external USB HDD, but i miss a single backup volume with sufficent space (2TB) .
Any pointer to a full data backup procedure (near 2TB needed) on several devices ?
Well you could put one of the new 2TB drives in a USB enclosure and backup your data to that. Then do another backup of your most important data to your other NAS and external USB hard drives.
Then do a factory reset and hot-add (add while NAS is on) the 2TB disk you put in a USB enclosure to the NAS.
