volpone
Feb 21, 2012Aspirant
Mixing brand model and size to upgrade storage space?
Hello all, I need to upgrade my X86 ReadyNas Pro Pioneer (4.2.19) X-RAID2 4 drives setup to 6 drives setup to get more storage space. The four installed drive models WD 1TB Green WD10EADS-00L5B1 (...
volpone
Feb 22, 2012Aspirant
Thank you mdgm for your detailed instructions.
Regards
Volpone
I'm not sure to understand the hot-plug / wipe procedure. In my idea (from my 4*1TB X-RAID2 current setup) it was sufficient to add the 2 new 2TB disks and then factory reset to wipe and rebuild completely the array (after a having done a full data backup obviously).Then reinstall add-ons and restore the data backup. Where i am wrong ?
mdgm wrote: Well you could replace two disks one at a time, hot-remove disk, wait say half a minute then hot-add again...
OK for external backup using one of the new drives, any pointer on an USB external enclosure supporting 3TB drives (i'm not sure if i'm going to buy 2 or 3 TB new disks) ?
Well you could put one of the new 2TB drives in a USB enclosure and backup your data to that. Then do another backup of your most important data to your other NAS and external USB hard drives.Then do a factory reset and hot-add (add while NAS is on) the 2TB disk you put in a USB enclosure to the NAS.
Regards
Volpone
