shanekm
Mar 03, 2016Follower
mixing hdd speed
I have several spare desktop hdds. however they're different manufacturer /speed. 1. will NAS rn212 work with regular desktop hard drives? 2. Will it work if one hdd is 7200rpm and other 5400rpm
kohdee
Mar 07, 2016NETGEAR Expert
1. Yes. You can use disks that are not on the HCL but you use them at your own risk.
2. The 7200 RPM should operate slower than 7200 RPM since you have 5400 RPM drives in the mix. Can only go as fast as the slowest disk.
Mar 08, 2016Guru - Experienced User
I'm not sure that's strictly true.
Reads can be done from both disks in the RAID-1 array in parallel, so you can go faster than either disk alone. Writes need to be mirrored, so they will potentially slow down some.
But real-world speed is often limited by network bandwidth anyway.
