scaryant
Jan 19, 2009Aspirant
Moblock (IP Blocker) for ReadyNAS
Hi, I've been investigating the install and config of Moblock for my ReadyNAS, but with my relatively limited knowledge of debian packages, I've hit a bit of a brickwall. Has anyone been able to in...
scaryant
Jan 20, 2009Aspirant
It is for P2P... thanks for the tip on the add-on.
I see it supports encryption, however I can't see any option to configure IP Blocking. Does this have to be done via the console or am I missing something here? I also notice after some investigation that there is a newer version (1.50d) than the one available in the add-ons, which one should I be using? Does v1.42 support the IP Blocking functionality?
Thanks again
Thanks again
