scaryant
Jan 19, 2009Aspirant
Moblock (IP Blocker) for ReadyNAS
Hi, I've been investigating the install and config of Moblock for my ReadyNAS, but with my relatively limited knowledge of debian packages, I've hit a bit of a brickwall. Has anyone been able to in...
scaryant
Jan 20, 2009Aspirant
Great, thanks.
For your information your install script installs the cron job to cron.dayly instead of cron.daily so it wont work. I have just manually moved it to the correct folder.
Is there a change log for 1.50e that I can view and should I be upgrading to the latest version? Are there bugs in 1.42 or have you simply added new functionality?
Thanks again
Thanks again
