Piyush_tambe
May 17, 2016Aspirant
model:2120 Hi i have readynas 2120 previously it was having 3 harddrive of 2 tb after adding a extra
model:2120 Hi i have readynas 2120 previously it was having 3 harddrive of 2 tb on x raid total space was 3.63 gb But after adding one more hardive of 2 tb the space is still same 3.63 gb ? P...
- May 18, 2016
Your volume has now expanded.
You shouldn't have filled your volume so full. It was 100% full before it was expanded. You should keep your volume usage under 80%. We do warn about volume usage when it exceeds 70%.
mdgm-ntgr
May 18, 2016NETGEAR Employee Retired
Is a resync currently in process? Can you send in your logs (see the Sending Logs link in my sig)?
Piyush_tambe
May 18, 2016Aspirant
Logs sended
- mdgm-ntgrMay 18, 2016NETGEAR Employee Retired
One of your disks has been marked as spare. I have sent you a PM.
Replied to your PM.
