tigerten
Apr 02, 2023Luminary
Monolithic flat disk image available
I have created a monoflat disk image files for the virtual ReadyNAS OS 6.6.0. This can be deployed within ESXi . I believe it should work with proxmox as well. Let me know if there is an interest s...
eton
Apr 16, 2023Luminary
Cool! How did you do it?
- tigertenApr 17, 2023Luminary
I used command:
vmkfstools -i ReadyNASOS.vmdk ReadyNASOS_thick.vmdk -d zeroedthick
and it works well.
- etonApr 17, 2023Luminary
Did you first convert Netgears IMG-file to VMDK?
https://www.netgear.com/support/product/readynas_os_6#download
Or where does the VMDK file come from? I am not familiar with vmkfstools.
- tigertenApr 17, 2023LuminaryNo. I don’t think you can convert that IMG file. There is an older VM image 6.6.0 online. It upgrades to 6.10.8 automatically.
If someone can find a way to convert that IMG. It would be awesome
