tigerten
Apr 02, 2023Luminary
Monolithic flat disk image available
I have created a monoflat disk image files for the virtual ReadyNAS OS 6.6.0. This can be deployed within ESXi . I believe it should work with proxmox as well. Let me know if there is an interest s...
eton
Apr 16, 2023Luminary
Cool! How did you do it?
tigerten
Apr 17, 2023Luminary
I used command:
vmkfstools -i ReadyNASOS.vmdk ReadyNASOS_thick.vmdk -d zeroedthick
and it works well.
- etonApr 17, 2023Luminary
Did you first convert Netgears IMG-file to VMDK?
https://www.netgear.com/support/product/readynas_os_6#download
Or where does the VMDK file come from? I am not familiar with vmkfstools.
- tigertenApr 17, 2023LuminaryNo. I don’t think you can convert that IMG file. There is an older VM image 6.6.0 online. It upgrades to 6.10.8 automatically.
If someone can find a way to convert that IMG. It would be awesome- etonApr 17, 2023Luminary
Thanks for clarifying.
Interesting that the Netgear vmdk-file needs some massage to work with other platforms.
