GRex
May 20, 2014Aspirant
Monoprice UPS
Anyone know if monitoring and shutdown functions on a ReadyNAS 102 will work with this UPS from Monoprice http://www.monoprice.com/Product?c_id=108&cp_id=10839&cs_id=1083901&p_id=4153&seq=1&format=2 ? Is there any way to know short of just getting both, plugging them in, and finding out or hearing from someone with first hand experience? The UPS description says it comes with UPSMON software for Windows but I have no idea if that is any indication of ReadyNAS compatibility.
Thanks much.
Thanks much.
- mdgm-ntgrNETGEAR Employee RetiredIs there a reason you would like to get the Monoprice rather than another brand? Not sure whether that would work or not, but most APC UPS units with a USB port would work.
- GRexAspirantThere is always a reason. In this particular case the reason is that it's literally the only UPS out there with both 4 battery powered and 5 surge protected only outlets, surge protection for ethernet and 2 coax lines, and rack mount-ability. At least for under $600 or so. Which is exactly what I need. The only feature I want that I'm not sure about is its ability to talk to a RN102, hence this post.
