tjech
Apr 30, 2020Aspirant
mount-block-root-25e boot error after power cut
Hi all, Our NAS just died with the mount-block-root-25e error, following a power cut. I've managed to make a USB boot device, but it doesn't boot from this either. Can anyone suggest a US...
- May 03, 2020
I had this same problem and i was trying to reload software on multiple usb drives and nothing was working. Then while searching on the netgear community for a solution, someone mentioned to run the USB software as administrator. So, I plugged in my USB drive right clicked the usb exe file and clicked on run as administrator and reformatted drive. I reinstalled the recovery software and tried loading from usb and it worked. Im not sure if running as administrator made a difference but as soon as I did that, the nas was able to recover from usb. Hopefully this works for anyone with the same issues.
Sandshark
Apr 30, 2020Sensei
I have had luck with some older Lexar "Twist/Turn" 2GB ones, which are probably not even availble anywhere, even on legacy machines (which are even more particular). A cheap 8GB I bought on eBay also worked the one time I tried it.
