PSC123's avatar
PSC123
Move disks between ReadyNAS 314 and 2120v2
Hi, I am new to the forum and hope someone may be able to help me.   I have an existing ReadyNAS 314 (4*2TB Disk), which is a desktop device.  As part of a move to a new house, I have installed a 1...
  • mdgm-ntgr's avatar
    Sep 07, 2016
    The 314 is x86 and the 2120v2 is ARM.
    If you haven't got the 2120v2 yet I would get the 3130 or 3138 which are x86
    Whilst you can move disks from x86 to ARM, I think, this is not recommended.
    Either way you should update you regular backup before moving your disks across (keep the disk order the same).
ProSupport for Business
