cemery's avatar
cemery
Follower
Jul 14, 2017
Moving Devices
I currently have 2 RND4210's and 1 RN10211D. They are connected to our network through a switch into the server. We aremoving our office and changing our network setup. The network will consist of 2 PCs, router and the NAS devices. Am I able to connect the NAS devices into the router to access and store documents and files or do I need toconnect the NAS devices into a switch then into the router? We want to eliminate our server and simplify our network to more of a home group. What is the easiest and simpliest way to connect the NAS devices so we can retrieve and store from 2 PCs and perform our backups?
  • Try avoiding bottlenecks. If both PCs have wired connection, then connect both PCs and the three NASes to the switch, then the switch to the router. If both PCs are connected to the router via WiFi, connect the NASes to the router. The multiple LAN ports on your router are nothing more than a small builtin switch.
    • StephenB's avatar
      jak0lantash wrote:
      Try avoiding bottlenecks...
      I totally agree.
      If the router doesn't have enough ethernet ports (which might be your situation), then get a switch that does, and connect all the wired devices to that switch.  If you have multiple switches, then the connections between them can become bottlenecks.
      The router's wifi won't be able to deliver a gigabit of throughput, so I think it's fine to keep the NAS on a switch if this is your situation.
      • jak0lantash's avatar
        jak0lantash
        Mentor
        Depends of the WiFi and the switch ;)
        But yeah, it's unlikely that the router is capable of 802.11ac and the switch FastEthernet :D
        You're probably right, connecting everything to the switch covers most situations anyway.
  • What is the server doing in your current setup?
ProSupport for Business
