bubi
Mar 14, 2016Aspirant
Moving disk from ReadyNAS Duo v1 to ReadyNAS 10400
I'd like to update my ReadyNAS Duo (2 bays) with a ReadyNAS10400. Actually, my ReadyNAS is configured with 2 HD in RAID 1 and 1 independent HD attached to external USB (formatted in NTFS). Can I in...
- Mar 14, 2016
bubi
Mar 15, 2016Aspirant
I understood that the best thing is to backup everything.
About installing NTFS disk in an already running system?
BrianL2
Mar 15, 2016NETGEAR Employee Retired
Hi bubi,
Are you asking if it's safe to plug in an external USB disk that is formatted with NTFS? If yes, that would be fine.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBMar 15, 2016Guru - Experienced User
BUT if you are asking if you can add an NTFS internal drive to the NAS array, then the answer is no. The NAS needs to reformat it.
BrianL2 wrote:
Are asking if it's safe to plug in an external USB disk that is formatted with NTFS? If yes, that would be fine.
