patdman81
Jul 05, 2022Tutor
Moving from single redundancy to dual - RNDU6000
I am runnning a ReadyNAS Ultra 6 (RNDU6000) on OS v6.10.7 I have 5x 8TB disks in the bays and it's currently setup as X-RAID/RAID 5. If I want to add a 6th disk as dual redundancy, how do I best ac...
Jul 06, 2022Guru - Experienced User
patdman81 wrote:
If I want to add a 6th disk as dual redundancy, how do I best achieve this?
I recall reading about changing to Flex-RAID first and then adding a final disk and choosing how it's used.
Is this correct?
Yes. You will need to ensure that this disk is as large as the biggest one in the array (and there need to be 3 disks already in the array of that size).
After adding the new disk for redundancy, you should be able to switch back to X-RAID if you like.
Once you are using RAID-5, future expansion will require upgrading 4 of the disks to the new larger size.
patdman81
Jul 06, 2022Tutor
Sounds good, thanks Stephen.
If I want to enlarge my storage in the future, are you saying that I would need to upgrade at least 4 of the disks?
I'm ok with that, but in that case, what would the steps be?
e.g. If I move from 8TB drives to 16TB drives in the future, would I swap out one at a time and after each swap, let the re-sync happen, getting my extra storage after the 4th 16TB has been swapped in?
You are indeed the forum guru, thanks for answering all my questions!
