patdman81
Jul 05, 2022Tutor
Moving from single redundancy to dual - RNDU6000
I am runnning a ReadyNAS Ultra 6 (RNDU6000) on OS v6.10.7 I have 5x 8TB disks in the bays and it's currently setup as X-RAID/RAID 5. If I want to add a 6th disk as dual redundancy, how do I best ac...
patdman81
Jul 06, 2022Tutor
Sounds good, thanks Stephen.
If I want to enlarge my storage in the future, are you saying that I would need to upgrade at least 4 of the disks?
I'm ok with that, but in that case, what would the steps be?
e.g. If I move from 8TB drives to 16TB drives in the future, would I swap out one at a time and after each swap, let the re-sync happen, getting my extra storage after the 4th 16TB has been swapped in?
You are indeed the forum guru, thanks for answering all my questions!
