petermac
Feb 06, 2020Apprentice
Moving readynas volume to new NAS
I had a volume containing 4 drives on an older ReadyNAS 316 that died. I purchased a new 424 to put the drives in and while the system will boot to the admin menu and it does see the new volume is th...
Feb 07, 2020Guru - Experienced User
petermac wrote:
I had a volume containing 4 drives on an older ReadyNAS 316 that died. I purchased a new 424 to put the drives in and while the system will boot to the admin menu and it does see the new volume is there it cannot mount it.
Any suggestions on how to make the volume active again?
The best way is to use paid Netgear support (my.netgear.com). It might not be covered by your 30-day phone support (which certainly wouldn't stretch to data recovery).
- SandsharkFeb 07, 2020Sensei
Did you put the drives in in the right order? The NAS can typically sort that out, but I've seen problems when all 4 drives are not the same size,
If you didn't mark them and have access to an old log .zip file, you can find the order by serial number in disk_info.log.
- petermacFeb 10, 2020Apprentice
Finally managed to mount the volume as ready only. Now to back them up.
