Pedro45
Nov 26, 2019Aspirant
Multiple NAS drives in a non-RAID (JBOD) configuration?
I have a Netgear ReadyNAS214 (latest OS) which had a single drive as it was/is intended as a backup to machines on the network – "JBOD", no RAID required or wanted. When I introduced a second dri...
- Nov 26, 2019
Did you try to do a factory default? That would be needed if you were still using XRAID. I thought based on your earlier post that you have already gone back to JBOD. FWIW, it wasn't needed to simply add a JBOD volume.
In an event, if that is what you are doing, then the NAS admin password has been reset to password. The NAS will by default use XRAID. So when you get past the wizard, you should
- switch to flexraid
- destroy the data volume
- create two jbod volumes, one for each disk
There is no need to wait for the XRAID volume to build/resync.
Nov 26, 2019Guru - Experienced User
Pedro45 wrote:
Obviously I'm missing something needed to achieve the desired "dual JBOD" configuration. Any suggestions?
Change to flexraid before you add the second disk. You do that on the volume page - if there is a green stripe on the XRAID control, then XRAID is enabled. Click it, and the system should change to flexraid.
Then select the disk on the volume page after you hot-insert it. If the disk is used, then you'll need to use the format control on the page. After that, create a second JBOD volume.
I suggest reading through chapter 2 of the software manual ( http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf ).
