netkid1
May 26, 2020Initiate
My Netgear Two Step Verification
Hi Folks,
I have seen a few threads in other products that reference Two Step Verification in the My Netgear account however I am unable to see any settings related to Two Step verification. How does one activate Two Step Verification such that when using readycloud/my netgear onelogin it prompts for two step verificatioin? Thanks
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
Not sure if the two step verification is available on readycloud.netgear.com at the moment. It is available if you are using Insight Portal or App.
If you have not setup the feature, when you login to insight.netgear.com using a new device or another device you have it will get you to the page where it will ask if you want to setup the security feature.
You may also want to login to Insight mobile app to setup the feature.
https://kb.netgear.com/000059590/What-do-I-need-to-know-about-two-step-verification-in-Insight
HTH
- HeikAspirant
So there is no possibility to activate 2fa / 2-Step Verification for readycloud.netgear.com?
This would be stone age in the year 2020 and a real security vulnerability in readycloud.
Yes, 2FA is not used on the ReadyCloud portal. There may be plans but not really sure if it will be pushed as Insight is the one using it.
HTH
