WesleyB
Apr 11, 2016Follower
My Ready NAS Duo will not go into the reset mode.
I have followed the instructions and the NAS RND2110-100NAS will not go into the Boot menu. All I get is the power button light flashing. Do I have a bad board, or it it operator error? I have tried...
Starlionblue3
Jun 14, 2016Tutor
I'm having a similar issue. I had to run a reset since the unit is non-responsive. I've tried reseating the memory.
Now after trying to reset I get the disk 1 LED flashing twice slowly, then the power, ACT and disk 1 LED all flashing together three times quickly. Then repeat.
I've tried resettting but no go.
Any ideas?
BrianL2
Jun 15, 2016NETGEAR Employee Retired
Hi Starlionblue3,
Can you check if you're using a V1 or V2 unit? Kindly check this page for more information.
Kind regards,
BrianL
NETGEAR Community Team
- Starlionblue3Jun 15, 2016Tutor
BrianL2 wrote:Hi Starlionblue3,
Kind regards,
BrianL
NETGEAR Community TeamThe bottom says RND2000 v2 but the back looks like a V1. It has the smaller fan.
Update: I reseated the memory for the nth time and now it takes the reset, as in I don't get the triple flash. It did the first flash after 5 and second flash after 25. However now it has been sitting for hours with pulsing blue. Is this the disk check?
- BrianL2Jun 15, 2016NETGEAR Employee Retired
Hi Starlionblue3,
Thank for providing the info that I asked for. Could you run the RAIDar utility to see what the device does? If this sits for more than 30mins or an hour, I suggest that you try another hard disk (a fresh one) and do the same reset procedure.
Kind regards,
BrianL
NETGEAR Community Team- Starlionblue3Jun 16, 2016Tutor
Kind regards,
BrianL
NETGEAR Community TeamHi again.
I don't have Java installed so I can't use RAIDar. (I know, I know...)
I tried another disk and factory default. However I have a hard time believing both the old disks are broken. Is there any way to "reboot" the old disks in the Duo now that I have reset it to factory default?
