WesleyB
Apr 11, 2016Follower
My Ready NAS Duo will not go into the reset mode.
I have followed the instructions and the NAS RND2110-100NAS will not go into the Boot menu. All I get is the power button light flashing. Do I have a bad board, or it it operator error? I have tried...
Anonymous
Jun 18, 2016Try use another browser. I have just tried it and the HCL displays properly for me.
FWIW, to recognize a Duo v1 from a v2:
The v1 is a SPARC unit running RAIDiator 4.1, with a blue and orange GUI. On the front, it's written ReadyNAS Duo. If you have a "v1v2" (version 1 hardware revision 2), the bottom sticker will say RND2000 v2, but it's still a Duo v1.
The v2 is an ARM unit running RAIDiator 5, with a black and grey GUI. On the front, it says ReadyNAS Duo v2. The bottom sticker will say RND2000-200EUS (the last three letters may change depending on the standard of power socket).
