Schinway
Jan 02, 2014Aspirant
My ReadyNAS died. How do I save my data???
My ReadyNAS Ultra 2 has died and now shows both hard drives as dead. It still boots up but but intermittently shows 1 hard drive working so I'm sure that it is a hardware issue and not that both work...
Jan 02, 2014Guru - Experienced User
They would need to be in a pro or ultra to be immediately readable. It is also possible to mount the volume in an x86 linux system, though I don't know the command sequence to do so.
Have you tested the drives with vendor tools in a PC?
