Schinway
Jan 02, 2014Aspirant
My ReadyNAS died. How do I save my data???
My ReadyNAS Ultra 2 has died and now shows both hard drives as dead. It still boots up but but intermittently shows 1 hard drive working so I'm sure that it is a hardware issue and not that both work...
Mace_Windoo
You need to follow the factory reset steps explicitly in this situation. Holding in the reset button during boot should take you to the boot menu, from there you can select factory reset.
http://www.readynas.com/kb/faq/boot/how ... o_2_duo_v2
"corrupt root" usually implies there is something on the drives
