KenPC
Oct 21, 2020Aspirant
N102 Doesn't boot after adding second HDD
I have a 6TB drive inserted with my data on it. Configured with JBOD and X-RAID disabled. I have a 2TB HDD I want to insert to add to my pool of storage. When I boot up the NAS with the second HDD in...
- Oct 21, 2020
You shouldn't format the drive before inserting it, you need to unformat it. That is, remove all partitions. The NAS can get confused if it sees two boot partitions. But the fact that it's causing a reset of the NAS when hot inserted may indicate there is something actually wrong with the drive or that the NAS has insufficient power for both drives (which should not be the case, so something is wrong with the NAS. power brick., or drive).
Oct 21, 2020Guru - Experienced User
KenPC wrote:
I've tried hot inserting it. causes a sudden reboot and unable to fully boot.
Maybe try
- powering down the NAS
- inserting the 6 TB drive in the second bay (leaving bay 1 empty)
- powering up the NAS
and confirm that the NAS boots with a drive in the second bay.
If that works, then I suggest testing the 2 TB drive. If you have a Windows PC, then connecting the drive to the PC (either SATA or USB adapter/dock) and using vendor tools (Lifeguard or Seatools) is best. I normally run both the full non-destructive test and the full write/erase test - sometimes failed drives will pass one, but fail the other.
Sandshark
Oct 21, 2020Sensei
- KenPCOct 21, 2020Aspirant
I feel stupid now. I had another Netgear branded power plug that is supposed to be for a dumb 4 port switch powering the NAS. I found the origional brick and plugged it in. All's fine now.
