AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
chirpa
May 15, 2013Luminary
I've seen the same on OS6, though on the #notsupported method of running it on an Ultra2. In my case, btrfs/kernel memory is doing something weird. Via SSH, the system says 'out of disk space', even though clearly has space, likely some memory leak. The GUI (readynasd) is unusable because it cannot write to its database (disk full), so it won't even load up. Only a reboot resolves it for ~12 hours.
If you have SSH, are you able to even try 'touch ~/test', or does it report disk full in that state?
Out of curiosity, I went poking around, and found that if I disable the space_cache option on this mount point, the 'out of disk space' issue goes away, not requiring a reboot to get back to sane function.
$ ssh root@10.1.2.1
root@10.1.2.1's password:
Welcome to ReadyNASOS 6.0.5
# touch test
touch: cannot touch `test': No space left on device
# free
total used free shared buffers cached
Mem: 1009736 765592 244144 0 1272 563856
-/+ buffers/cache: 200464 809272
Swap: 523964 0 523964
# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 2.2G 1.4G 62% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 2.2G 1.4G 62% /
tmpfs 494M 4.0K 494M 1% /dev/shm
tmpfs 494M 7.1M 486M 2% /run
tmpfs 494M 0 494M 0% /sys/fs/cgroup
tmpfs 494M 0 494M 0% /media
/dev/md127 927G 215G 675G 25% /data
/dev/md127 927G 215G 675G 25% /home
/dev/md127 927G 215G 675G 25% /apps
# mount
tmpfs on /dev type tmpfs (rw,relatime,size=10240k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/md0 on / type btrfs (rw,relatime,space_cache)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu type cgroup (rw,nosuid,nodev,noexec,relatime,cpu)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=24,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
tmpfs on /media type tmpfs (rw,nosuid,nodev,noexec,relatime,mode=755)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/md127 on /data type btrfs (rw,relatime,space_cache)
/dev/md127 on /home type btrfs (rw,relatime,space_cache)
/dev/md127 on /apps type btrfs (rw,relatime,space_cache)
# mount -o remount,nospace_cache /
# mount
/dev/md0 on / type btrfs (rw,relatime,nospace_cache)
# touch test
# df -h
rootfs 4.0G 2.1G 1.4G 62% /
/dev/md0 4.0G 2.1G 1.4G 62% /
