AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
Skywalker
May 15, 2013NETGEAR Expert
RN104 uses ext4 for the root filesystem, so this is likely something different.
chirpa, can you try running:
I've also seen apps that would create large files on root, then unlink them while they're still in use -- thereby not actually freeing the space. So that would be another possibility.
mount -o remount,clear_cache /
