AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
benny90
Jun 02, 2013Aspirant
Hello,I have the same issues.
My NAS RN 104 keeps freezing, and when this happen Raidar cannot find it as it is disconnectiing and the NAS does not respond at all when I press the power button 1 or 2 times, the display remains black....
The only way to reboot is to unplug the power cable and then it works for few hours and crash again...
My configuration:
- Win 7
- Firmware 6.0.6
-4 x 2To WD Red RAID5
Network configuration: Router -> CPL-1 (devolo AVPlus200 -> Switch (GS105E or GS108Ev2) -> NAS
- Cable: Cat 5e or Cat 6 ( I tried both).
I have downloaded the Logs files from the Web Interface if you need.
I also tried to to fix the ip manually and not with DHCP without success...
Hope you can help me because I am stuck...
My configuration:
- Win 7
- Firmware 6.0.6
