AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
Jun 03, 2013Guru - Experienced User
Did they look at the logs?
You could escalate the support request to level 3.
Or perhaps do an RMA.
Another option is to test the disks in a PC (WDC's lifeguard program). Though you'd need to power down the NAS before you remove them.
