AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
roygaard
Nov 25, 2013Aspirant
Another BIG problem is this (sorry) stupid minidlnad that seems not to be designed for single-core-cpus. Disabling ReadyDLNA (=minidlnad) gives you a HUGE performance-boost.
You can use this little commandset to check the "death/sleeping" processes that are causing the IO-problems on this box:
For example:
To make miniDLNA sweat copy some JPEGS or movies onto a DLNA-enabled share while minidlna is running and watch the IO-wait grow into heaven.
You also can disable DLNA while copying MANY files onto the box, what in my opinion makes no sense, but maybe helps.
Kind regards,
Roy
# for HH in $(seq 1 1 10); do ps -eo state,pid,cmd | grep "^D"; echo "---========================================---"; sleep 5; done
For example:
root@readynas1:/tmp# for HH in $(seq 1 1 10); do ps -eo state,pid,cmd | grep "^D"; echo "---========================================---"; sleep 5; done
D 7672 chattr -c /data/sabnzbd
D 1355 [btrfs-transacti]
D 7684 /usr/sbin/minidlnad -S
D 7689 rm -rf /apps/.readydlna/files.db /apps/.readydlna/art_cache
D 1922 [flush-btrfs-1]
D 7695 /usr/sbin/minidlnad -S
D 772 [jbd2/md0-8]
Kind regards,
Roy
