AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
Dec 20, 2013Guru - Experienced User
Obviously the crashing problem is real, and I hope it will be solved soon.
But even if the system isn't crashing, you need a backup. I understand it is expensive, and not always convenient. But if you trust your data to a single device, you will lose it at some point. It is just a matter of when.
