AndrewT1
May 15, 2013Aspirant
NAS 104 locking up
Hi.. I having an intermittently problem with my NAS 104 (sw 6.0.5) after a few days of operation the unit freezes , no response from the web or Power button. The only way to recover is to remove th...
xeltros
Dec 28, 2013Apprentice
Unless you're are speaking in farenheit degrees (in which case CPU is 62°c and disks 33°c (which seems normal, even cool to me) and you wouldn't worry I guess), that's way too hot.
My CPU never did go above 80°C. My disks never go over 45°C no matter what. Let's say CPU to 90°c and disks to 50°c under really heavy load could be normal (and I took high values), but you are way above that. I'd see with the support too.
My old computer graphic card froze at 125°c (had a problem with the fan), so imagine a CPU which is normally cooler than graphic card when playing games at 142°c that's crazy. If you want to, check if the NAS' fan works, try to switch off the NAS and unplug the electrical outlet, that way you'll be sure it will do a proper boot and check every component while booting (I believe ARM devices also have POST, not sure of that but would seem normal).
