Nixxon
Nov 18, 2019Aspirant
NAS 626x New Hard Drive
Hello, I recently installed a ReadyNAS 626x. I stated out with two HDD and just added a third. They two show up and are able to be used. The 3rd is listed, however it did not increase the disk ...
Sandshark
Nov 18, 2019Sensei
Did you insert the drive with pwer on or off? If with power off, try pulling it, waiting a couple minutes, and re-inserting.
You may also find some clues as to what is going on in the log zip package. mdstat.log, lsblk.log, sgdisk.log, and smart_history log would be places to look.
