that_guy
Jul 21, 2020Aspirant
NAS: After normal powerup blue light flashes twice then nothing - No LAN LEDs - No HDD LEDs
NAS has been in service for for a few years. Disks have been in service for a few years. Was plugged into a UPS system, but the storm knocked power out longer than the battery lasted, so was abruptly...
- Jul 22, 2020
That worked! I'm in. Shares and volumes look in-tact.
You sir are a f***ing genius.
netgearGive this person a promotion and a raise.
Dead serious. I've risen from the ashes.
Man, I'm about done with 2020. Not even safe working from home these days.
Re: Backup strategies, I'm assuming you had something in mind like online?
Care to offer up suggestion?
This is about 3-4 months of my life's work. I trusted it to Netgear and now glad I did. Got a bit bumpy there, and not going to lie was scared.
I want to be prepared 100% for future.
I was sure that a NAS, with UPS + Enterprise drives in RAID 1 was good enough.
I attached a screenshot here, so you can see, I don't run anything exotic on here, solely used for work, no apps.
Thanks again StephenB you saved my bacon. If you're ever in the SW corner of Ohio. Lunch is on me mate.
that_guy
Here's a picture of the sticker on the bottom of the unit.
I've edited out the S/N# and MAC addresses, but can send original via email to support if needed.
- SandsharkJul 21, 2020Sensei
So, you have an UPS, but the NAS is not montitoring it so it can do a proper shut-down when the battery reaches critical charge? That elimnates a big part of what an UPS does for a NAS.
What status does RAIDar give you? What status does it give if you boot without the drives?
- that_guyJul 21, 2020Aspirant
1) Cheap UPS, 400W. Didn't do anything like that. It's now attached to a Cyberpower 900W UPS that does.
2) Cannot be seen with the newest RAIDar app from Desktoip
3) Without drives, it boots up similar, all up until the point where the blue light flashes twice, but instead of twice it flashes once - then goes dark. No lights on front at all - fan still spins - but no lights at all.4) Tried also with 1 HDD, then 2HDD - same result as #3
- StephenBJul 22, 2020Guru - Experienced User
that_guy wrote:2) Cannot be seen with the newest RAIDar app from Desktoip
did you also try this with the disks removed?
If RAIDar can't see it with the disks removed, then something went wrong with the chassis.
A USB recovery might bring it back. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
Also, check the warranty status (5 years for the original purchaser).
that_guy wrote:
I have lots of data on these drives I would like to preserve, and find it almost impossible that both drives died in tandem.
While it seems impossible, we have seen it here. One aspect is that often users don't realize one of their drives had failed earlier.
I do suggest connecting them to a Windows PC (USB adapter/dock or SATA) and testing them with Seatools.
If you purchase (or get an RMA) of an x86 ReadyNAS you can directly migrate the disks.
There are also beta versions of mdadm and btrfs available for Windows that you could try - they should give you access to the files.
