penyart
Jan 08, 2016Aspirant
NAS DUO System Failure
I am new to supporting my NAS though I have had it for years. I just did the plug an dplay and moved movies and musing into the sytem, primarily. I have two 500GB 3.5" drives installed running Raid X...
- Jan 11, 2016
Thanks for all the help. I successfully added two new 1 B drives and am wokring at recovering the dta from the two 500GB drives I removed. I am also investigating the best backup system to this back up system using the USB backup funciton.
Thank you again!
Hope your year delivers you success and happiness
JennC
Jan 08, 2016NETGEAR Employee Retired
Hello penyart,
What RAID level is it using?
If that is XRAID (RAID1 automatically on ReadyNAS Duo), you should be able to recover data without the failed disk leaving the one that is not reporting dead/faulty inserted.
penyart
Jan 11, 2016Aspirant
Thank you again!
- BrianL2Jan 11, 2016NETGEAR Employee Retired
Hi penyart,
We're glad that everything worked out well. I hope that you will share ideas and contribute to the NETGEAR community.
Kind regards,
BrianL
NETGEAR Community Team
