baesens
Apr 02, 2017Aspirant
nas not discovered
 Hello,     I recently acquired a ReadyNAS314 on which I want to store my music files. Ia also own a Yahama CD network reader CD-N301. Both the CD-N301 and the ReadyNAS are on the same netowirk. I act...
- Apr 11, 2017
Hello FramerV
I checked the version on my ReadyNAS314. It is 6.6.1. When I click on "check for upgrade", the nas tells me there is no available upgrade (see below a screen capture)
Best regards,
Pierrot Baesens
FramerV
Apr 09, 2017NETGEAR Employee Retired
Hi baesens,
What firmware is the ReadyNAS using? Might be best to update that.
- baesensApr 10, 2017Aspirant
Hello FramerV
When I installed first my ReadyNAS, it asked me to upgrade the firmware, so that I suppose it is update. As far as I remember, it is version 6.6.2
Pierrot Baesens
 - lecgrossiApr 22, 2017Aspirant
I am having a similar problem I can see the unit when I use it's address 10.0.0.229, but not when I log in. Then it says the unit is off line. same happens for my iPhone app.
- StephenBApr 23, 2017Guru - Experienced User
Are you meaning that ReadyCloud is saying the NAS is off line? If so, read through this: https://community.netgear.com/t5/ReadyCLOUD/Having-ReadyCLOUD-problems-since-3-30-17/td-p/1259697
