ldyork
Apr 08, 2020Tutor
NAS Raidar showing flashing yellow light on drive 1
I had a power supply connector burn up at the chassis connection on this unit and upon replacing it and checking things out I notice drive 1 status light in the Raidar app is blinking yellow. I thin...
- Apr 09, 2020
Volume status shows it's in recovery and about 80% done. Logs show it has had random errors over the last 3 months and half a dozen failures to contact smtp server which probably explains why I never got a notification it was in trouble. I plan to replace the disk but I wanted to Replace it with a Seagate ST31000340NS but a note says if the firmware level is SN03 or SN04 I have to use Raidiator 4.01. The version I was going to buy is at level SN05. Does that mean I have to use 4.01? Currently using 5.3.13 Not even sure 4.01 is compatible with this NAS.
Apr 09, 2020Guru - Experienced User
Try hovering your mouse over the drive icon, that should give you more status.
