ldyork's avatar
ldyork
Tutor
Apr 08, 2020
NAS Raidar showing flashing yellow light on drive 1
I had a power supply connector burn up at the chassis connection on this unit and upon replacing it and checking things out I notice drive 1 status light in the Raidar app is blinking yellow.  I thin...
  • ldyork's avatar
    ldyork
    Apr 09, 2020
    Volume status shows it's in recovery and about 80% done.  Logs show it has had random errors over the last 3 months and half a dozen failures to contact smtp server which probably explains why I never got a notification it was in trouble.  I plan to replace the disk but I wanted to Replace it with a Seagate ST31000340NS but a note says if the firmware level is SN03 or SN04 I have to use Raidiator 4.01.  The version I was going to buy is at level SN05.  Does that mean I have to use 4.01?  Currently using 5.3.13  Not even sure 4.01 is compatible with this NAS.
ProSupport for Business
