malcor50
Oct 08, 2023Aspirant
nas rn10200
bonjour a tous connection telepnone android et nasnetgear rn 10200 connection a distance via le web
schumaku
Oct 08, 2023Guru - Experienced User
ReadyCloud does not longer exist.
- malcor50Oct 09, 2023Aspirant
alors une autre solution svp merci
- StephenBOct 09, 2023Guru - Experienced User
Netgear isn't going to provide an alternative, so you will need to find something else.
There are a couple of options people have discussed here, but if you want some useful advice here, then you need to tell us more on how you used ReadyCloud. Many used it for mainly for backup, others to get remote access for themselves, or for sharing files with others. You won't find one solution for all of these service.
