SancioVFX
Jun 29, 2023Follower
NAS server Folder share permissions Issue
Hi Team, We are using ReadyNAS4312 Server for Sharing files & folders. we are giving the permissions to shared folder which user in domain but unable to giving this permissions to sub-fol...
schumaku
Jun 30, 2023Guru - Experienced User
- SandsharkJul 01, 2023Sensei
Are you saying users of a main folder are not getting the proper (same) permission to sub-folders or that you want to give different permissions to sub-folders. The NAS GUI is not set up for the latter. You can use Windows to do it, but the NAS may reset them, so it's not a good idea.
When you add a user, sometimes they don't get the right permissions to sub-folders. I believe that happens when they are a member of a non-owner group that has permission, but it doesn't always seem to happen and I've not figured out what else is in play. To fix that, you need to reset folder permissions in the GUI.
