wagwarnas
Jan 12, 2021Aspirant
NAS to replace Netgear ReadyNAS NV+
Hi, Can someone recommend a Readynas and drives? I need to replace my old Readynas NV+. I need about 4 tb of mirrored storage. Primay usage will be for photo files (2 TB) and about 1TB audio file...
Jan 12, 2021Guru - Experienced User
Do you literally mean "mirrored" - that is, RAID-1 or RAID-10? Or would you be ok with RAID-5 (which is redundant, but not mirrored).?
A two-bay platform would require 4 TB SSDs - which are fairly expensive, and wouldn't be expandable. If you could went with a 4-bay platform, you could go with three 2 TB SSDs initially, which would allow you to add another one later on if you needed to grow to a 6 TB volume.
As far as currently shipping platforms go, the RN212, RN214, RN422, and RN424 are all reasonable options. If you are looking at a used NAS, you could add in the RN202, RN204, RN312, and RN314. Inventory is scarce at the moment, and although I don't recommend competitor NAS products (I don't own any), I do suggest that you look at all competitor options also.
All the OS-6 ReadyNAS can handle 2.5" SSD SATA drives.
- wagwarnasJan 12, 2021Aspirant
Thank you for your quick response! I am using RaidX (I believe) and I have been very happy with that. I had a drive crash in my 4 bay NV+ and though I had to pay Netgear for tech supp, the tech was able to recover all of the data. I dont want to lose that. So my understanding is that is 2 drive volume with a 2 drive mirror. If that is not correct, let me know. I'm not sure what RaID LEVEL Raidx is.
I forgot to ask, what wireless protocols do the RN214 and 424 support? I have not found that info in the tech specs.
if my understanding is correct, I would need to populate the nas with 4 2TB ssd to get a 4tb volume. What SSD would you recommend or have you heard good things about?
Thank you.
- mdgmJan 12, 2021Virtuoso
wagwarnas wrote:I'm not sure what RaID LEVEL Raidx is.
On Sparc it uses RAID-4 (unlike RAID-5 it has a dedicated parity disk rather than distributing parity amongst all the disks). On newer ReadyNAS it uses RAID-5.
The NAS gets plugged in via ethernet to your router/switch. The wireless protocols are totally dependent on what your router and your client (e.g. laptop) support.
2TB SSDs are not cheap. SSDs will make a performance difference most notably for "random" read/writes over the GbE interface of the RN214 and RN424, but if doing large sequential transfers you'd want to be using the 10GbE ethernet interface of e.g. a RN524X to see a big increase in speed. 10GBASE-T equipment still isn't cheap. You'd need a switch that supports it and a NIC in your PC.
For a lot of users hard drives are still the economical way to go. I have several ReadyNAS and haven't yet used a SSD in any of them.
Thank you very much! I know that SSD are expensive, but I assume that an HDD would quickly fail in a high vibration and bumpy environment like a motorhome. I would have to shut it down to travel. I'd like to have it available while driving.
- StephenBJan 12, 2021Guru - Experienced User
That is not correct. 4x2TB will give you a 6 TB volume in X-RAID. The rule for capacity with XRAID is "sum the disks and subtract the largest".
I haven't used an SSD in my own NAS. If you look at the HCL, you'll find that Netgear has qualified Samsung 850 Pro and 860 Pro for ReadyNAS in both 2 and 4 TB sizes. So they would be safe choices (and have excellent reputations). https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
- wagwarnasJan 13, 2021Aspirant
Thank you very much for that info. I decided I would purchase the RN214, so I have been trying to find one online! it appears they are not to be found. I can only find one available new, it is the corrrect price, but it ships from the UK. Are they all mfg. here in the US? Would I have any problems? I cannot find any other vendor including Netgear itself that has one for sale! thanks.
