hnrkndr
Jun 23, 2022Aspirant
NAS212 : disk full, but stored data is much less than capacity
Hi! Newbie question about capacity of NAS212 with 2x 4TB, RAID1: Approaching 100% full disks, I have removed data (moved files back to the PC) from the NAS This cleared hundreds of GB, but after...
- Jun 24, 2022
It might be simplest to delete the volume, recreate it and the shares, and then move everything back.
Jun 24, 2022Guru - Experienced User
- SandsharkJun 24, 2022Sensei
How much is in home folders? The GUI doesn't show usage there. Do you have any ISCSI targets?
- hnrkndrJun 24, 2022Aspirant
Ohhhh! On the home drive, I found are hundred of folders with thousands of copies of previously deleted desktop files!!!
Thanks for pointing me at this discovery đ
The NAS seems to make timestamped copies of every file that once was placed on the desktop.
FYI, I use the PC desktop daily in my workflow as a temporary holding bay for up/downloaded files.
With 5 minutes of deleting some of these old temp files, I have gained substantial free space.
Thanks for your help đ
FYI, I do not use the "home" folders" for deliberate data storage at all; instead I have all my storage arranged in named shares.
I learned from the software manual that iSCSI targets have something to do with LUNs / LUN group on the ReadyNAS. Or something with 'iSCSI-Attached Device'
I do not have any LUNs set up on my NAS.
No attached devices either as far as I know.
Regards
Henrik
- Aug 07, 2016Retired_Member
