nswafford
Aug 29, 2016Aspirant
Need a replacement Disk Tray
I am missing one drive tray for a readynas 104. You'd think that something like this would be easy to find but I have had no luck. How/where can I buy one?
Thank you!
- Aug 29, 2016
It looks like they provided you an accessory RMA for a new tray (btw NETGEAR part code 290-10217-01)
Aug 29, 2016Guru - Experienced User
The RNDTRAY-10000S should fit, but you lose the tool-less feature.
Not something I have tried though.
mdgm-ntgr
Aug 29, 2016NETGEAR Employee Retired
It shouldn't be possible to lose a drive tray as the only time the disk tray should be removed is when removing/adding/replacing a disk. Or if the hardware failed and the chassis needed to be RMA'd you would keep the drive trays and the disks, and the external PSU (unless requested by support).
Yes. The old desktop drive tray will work in the new desktop NAS but not the other way around.
