joedrt
Dec 06, 2015Aspirant
Need a simple readynas
I'm new to the Netgear readyNAS systems, I haven't purchased one yet but I'm looking. I just want a NAS that is cloud accessible, simple to use (multiple people using it), fairly reasonable on p...
- Dec 07, 2015
Hi joedrt,
As a follow-up to mdgm and StephenB's responses unto you, kindly check these links for the RN200 series (Arm-based) and RN300/500/700 series (x86 or Intel-based) data sheets respectively below:
http://www.downloads.netgear.com/files/GDC/datasheet/en/RN200.pdf
http://www.downloads.netgear.com/files/GDC/datasheet/en/RN300-RN500-RN700.pdf
Let me also share these FAQ links below:
http://kb.netgear.com/app/answers/detail/a_id/29788/~/readynas-backup-faq
http://kb.netgear.com/app/answers/detail/a_id/29785/~/readycloud-faq
DaneA
NETGEAR Community Team
Dec 07, 2015Guru - Experienced User
RN300 series (and above) that were puchased after June 1 2014 have lifetime chat/email support, the RN200 series has only 90 days. So take that into account when you price out your options.
DaneA
Dec 07, 2015NETGEAR Employee Retired
Hi joedrt,
DaneA
- joedrtDec 07, 2015Aspirant
I understand the importance of support but I was looking at the price point. $400 + for a NAS is expensive for just the home use? or no? Like I mentioned im new to this so not sure on the range people are purchasing these items.
- StephenBDec 07, 2015Guru - Experienced User
They are specialized PCs, and are priced accordingly.
If you are price-sensitive you can look into 2-bay units or the RN104. There is a performance dropoff with the RN100 series, especially with streaming/plex. The RN200 series and above supports real-time transcoding, which is often needed.
maybe i will just wait and save some for a RN300 because im sure i will need support of some kind in the long run.
thanks to all who replied!
