nmoffitt
Jan 08, 2024Aspirant
Need to replace toasted 12V 5A supply for ReadyNAS V2
Hello community, The plug that inserts into my ReadyNAS V2 started to melt and burn. Fortunately, I caught it before it damaged my office. As a bonus, the drives are still intact (I tested with a...
- Jan 11, 2024
When you use the V1 supply with the V2, check the connector and see if it's getting warm. If it is, then you may still have a poor connection. If it isn't, then the issue likely was in the connector on the other supply. That replacement ReadyNAS supply does sound like a good option. While you may be able to simply replace the connector on the old supply, I wouldn't risk it with the low cost of a new supply.
Jan 09, 2024Guru - Experienced User
nmoffitt wrote:
The plug that inserts into my ReadyNAS V2 started to melt and burn. Fortunately, I caught it before it damaged my office. As a bonus, the drives are still intact (I tested with a supply from a V1).
Is the power socket on the v2 damaged? Or is it just the connector on the power brick?
- nmoffittJan 09, 2024Aspirant
The damage appears to be limited to the connector on the power brick, where damage can be seen on both the external and internal plastic parts. There's a small amount of smoke residual on the outside of the NAS at the power socket, but I was able to power it using a similar power supply from a V1 so I could make a backup.
