nattaboy
Oct 05, 2017Aspirant
Netgear Ready NAS NV+
Hi I am trying to fix and issue with a firends NV+ V1. 4.1.16 I am getting firmware errors and kernel panic issues. They have not backed up. Initially stuck on boot then Disc 2 crashed and replaced...
- Oct 08, 2017
If you had a 3-disk XRAID set up, then you can't resync with one disk missing.
Oct 06, 2017Guru - Experienced User
nattaboy wrote:
So my question is now if I were to put disc 1 back in slot one would this wipe all info on the disc 1?
It shouldn't (if you put it back with the NAS powered down). But you've done a lot of disk manipulation, so it's hard to be definitive.
You might consider data recovery, the more things you try the more damage can be done to the data. Netgear has a recovery service ( https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service ), some users have had good luck with ReclaiMe.
nattaboy
Oct 06, 2017Aspirant
Thanks for your response. So to be sure. The new disc is in slot 2. The sytem is up and running on latest firmware. I shut down leave the disc in slot 2 put the disc with the firmware error into slot 1 and let it sync?
- StephenBOct 06, 2017Guru - Experienced User
Well, it's not clear to me what it would sync with. The original disks 3 and 4 are still in the system?
- nattaboyOct 07, 2017Aspirant
There were only 3 discs in the system.
When ever I put Disc 3 in back in I get a kenel panic on reboot.
At the moment there is only disc 1 and 2 in so if it started to sync would that be wiping disc 1?
- StephenBOct 08, 2017Guru - Experienced User
