comicrage
Aug 17, 2017Aspirant
Netgear ReadyNas 312 Question. Can't see both hard drives
Hi, I just purchased a ReadyNAS 312 and have installed 2 - 1 TB drives. I connected the ReadyNAS directly to the back of the PC with the ethernet cable. When I open the RAIDar, it gives me t...
Aug 17, 2017Guru - Experienced User
By default your ReadyNAS uses RAID-1. That mirrors the disks (so anything written to one is also written to the other). The benefit is that you have some protection from disk failures, but of course you lose space.
If you want the space instead, you need to switch to FlexRAID, destroy the current volume, and then create two new ones (one for each disk).
That is described in the software manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
Read through pages 26-34 (at least).
