comicrage
Aug 17, 2017Aspirant
Netgear ReadyNas 312 Question. Can't see both hard drives
Hi, I just purchased a ReadyNAS 312 and have installed 2 - 1 TB drives. I connected the ReadyNAS directly to the back of the PC with the ethernet cable. When I open the RAIDar, it gives me t...
Aug 17, 2017Guru - Experienced User
By default your ReadyNAS uses RAID-1. That mirrors the disks (so anything written to one is also written to the other). The benefit is that you have some protection from disk failures, but of course you lose space.
If you want the space instead, you need to switch to FlexRAID, destroy the current volume, and then create two new ones (one for each disk).
That is described in the software manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
Read through pages 26-34 (at least).
comicrage
Thanks for the quick response. So, in the future, when I upgrade to 8 TB, I assume that I need two identical 8TB drives for the ReadyNAS 312 and the mirroring configuration, correct?
Again, thanks for the great information.
- StephenBAug 21, 2017Guru - Experienced User
Yes.
- MickatroidSep 01, 2017Aspirant
Remember though, having data stored on two drives could save your data (and all going well it will) when one drive fails but it should not be relied upon to do so.
If the whole NAS fails your data may still be lost (corruption, damage to drives etc), if one drive fails backing the good drive up (or re-mirroring it to a fresh drive) might cause the remaining working drive to fail. If someone steals your NAS your data will be lost.
Mirroring/RAID1 is not a substitute for proper backups.
- StephenBSep 01, 2017Guru - Experienced User
I agree. RAID is not enough to keep your data safe.
That is why I described the benefit as "you have some protection from disk failures"
