soiraipur
May 28, 2025Follower
Netgear ReadyNAS 4312V2
Hello Team, We are facing to access my shared folder. and need your support for the same.
May 28, 2025Guru - Experienced User
soiraipur wrote:We are facing to access my shared folder.
Note this is a user-to-user forum. All ReadyNAS models are end-of-life, so there is no Netgear support for them.
We need a lot more details on your problem. For instance,
- Is this a home folder or a share?
- What error are you getting?
- Are you seeing any errors in the NAS web ui (or the log zip)?
- What device are you using to access the folder?
- Is this happening to other users or other shared folders?
- Did something change that might have triggered the problem (for instance, a windows 11 upgrade)?
Sandshark
May 28, 2025Sensei
And is the NAS AD integrated, or are you using NAS-only credentials?
