Grimleiv
Jan 09, 2018Tutor
NETGEAR ReadyNAS Quick Installation vs new harddrives
Quick Installation, mounting holes in new harddrives.. only 2, one front and one hole back. So the middle hole is gone. Do you just cut of the middle plastic pin? And use the one pin back, or do they...
- Jan 09, 2018
Hi Grimleiv
Currently there are no replacement disk trays available for the RN100 series, though newer models supports the hard drives with no center hole.
You may want to check this thread and this thread regarding your concern.
I am pretty sure ReadyNAS team is working on getting replacements for newer hard drives we just can't provide any ETA.
Hope this helps!
Regards
Marc_V
Jan 11, 2018NETGEAR Employee Retired
Hi Grimleiv
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
